-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   Double pipe heat exchanger (http://www.cfd-online.com/Forums/ansys-meshing/91659-double-pipe-heat-exchanger.html)
mohcin August 18, 2011 07:09
I am trying to model a double pipe heat exchanger but whenever I try to mesh that model there is an error comes up as ' mesh exporter does not support overlapping geometry problem'. I dont know how to resolve this issue. Kindly help to resolve this issue.
Regards,
Mohsin
-mAx- August 18, 2011 07:48
post picture
mohcin August 18, 2011 10:04
I have solved that problem for the model in which both the fluids are water but if I used the model like :
Inner fluid = hot water
Inner pipe = copper
outer fluid = Phase change material (solid)
outer pipe = copper
then it gives errors like Access Violation?
Thanx
Regards
mohsin
anjan August 18, 2011 10:12
[QUOTE=mohcin;320604]Hi,
hi, it is a double domain channel, so 2 domains are necessary for flowing, first create a geometry a pipe in pipe, import that cad file into icem, declare all fields, inlet_1,outlet_1, inlet_2, outlet_2. first take a material point in inner pipe mesh it, and take another point and mesh it next.
