[GAMBIT] Unable to create .msh file due high order elements on meshed face error
Like Tree3Likes
  • 3 Post By -mAx-
Old   August 27, 2011, 11:38
Default Unable to create .msh file due high order elements on meshed face error
Ty@flent is on a distinguished road
Dear all
In gambit, after meshing and specifying boundaries, once i try to export the 2D file to fluent, the following error is generated
"Face Face 1 has higher order elements and cannot be exported to Fluent 5 format"
I have tried different mesh types and sizes but could not get rid of the error
The file pertains to an aerofoil created by joining 49 x,y points through NURB curve in gambit
Thanking in anticipation, please help
Ty@flent is offline   Reply With Quote
Old   August 29, 2011, 02:02
-mAx-'s Avatar
Maxime Perelli
did you change something in Set Face Element Type (surface/mesh)?
Default should be 4 node for quadrilateral and 3 node for triangle
Shayan, Ty@flent and naveensdas like this.
Old   August 29, 2011, 16:05
Yes. This was precisely the reason. The settings were found altered to higher values and restoring them to default enabled the mesh to be exported successfully to fluent by writing the .msh file.
Hats off to your judgement and many many thanks
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
