August 31, 2011, 06:50 |
Workbench: rotate a sketch..Please Help!
anonymous
Is it possible to rotate a 2D sketch in workbench? for example: a coordinate (0,1) will change to (-1,0). Thank you, |
August 31, 2011, 09:16 |
2D- sketch rotation
Mohankumar.G
yes you can rotate it using move command in modify.
Enter the degree in the box provided--- select the curves----Right click and select the paste handle or select default paste handle-------Again right click and select rotate by r degrees------Again right click and select the paste at plane origin ------- ESC. |
May 25, 2021, 07:43 |
#3 | |
Khan
Rep Power: 6 |
This was very helpful... Thank you |
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 09:23 |
PEM Fuel cell module meshes. ICEM vs workbench | aarvay | FLUENT | 24 | March 2, 2020 06:50 |
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes | rooftop | ANSYS Meshing & Geometry | 19 | March 31, 2016 02:33 |
Macro command combatibility ANSYS workbench | Tassos | CFX | 6 | January 13, 2014 04:19 |
Running Multiple Simulations from Workbench 12.1 | Josh | CFX | 3 | August 10, 2010 19:51 |
