September 5, 2011, 06:14 |
How avoid two surfaces's mesh stacking up? ?
Rockda Kasba
Rep Power: 15 |
I'm trying to mesh a 2D geometry using ansys wb 13 and need help for a little thing. You can see my configuration on joined picture. The grey part is a solid cylinder and the bigger cylinder surrouding him represent my fluid zone. You can see that i've added an additional surface inside the fluide zone in order to mesh more precisely this area ( which represent my jet impact zone) in the meshing tool. I'm not sure it is necessary to create a surface to do this but i dont know if it is possible to mesh more precisely a part of a surface without creating a new surface for it. My problem is that when i proceed meshing, my little surface is meshed two times. Indeed the entire cylindrical fluide zone surface is meshed and the little surface inside it meshed too a second time. So finally i've two mesh who stack up. How can i avoid this ? Thanks a lot |
Display Modes | |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 09:07 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? | jash | ANSYS Meshing & Geometry | 19 | July 23, 2013 19:48 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 14:40 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 13:21 |
