-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   creating cuts on a volume (http://www.cfd-online.com/Forums/ansys-meshing/92349-creating-cuts-volume.html)
lili September 12, 2011 03:28
hi
in gambit I want to creat a circular cut on top of a cylinder but it says "the requested operation can not be performed because the face of the cylinder has upper topology" do you know how it could be done?
-mAx- September 12, 2011 07:05
*post picture
*Real or virtual geometry?
lili September 12, 2011 14:54
the volume is real. how could it done?
-mAx- September 13, 2011 01:09
if your volume is real, than a simple split with any surface cutting entirely your volume should be successfull.
But the message you posted, sounds like you want to delete a surface, an edge or a vertex which belongs to your volume
