December 10, 2014, 01:13 |
problem in mesh output-->[Poblem Soved]
mehrzad
Rep Power: 14 |
PROBLEM SOLVED
Hello dear friends. I have encountered a problem with output mesh in ICEM. I have a room with an inlet and outlet when I mesh the domain with unstructured option provided in ICEM ther is no problem as in pictur 1. you can see both inlet/outlet in picture. but when I use blocking and mesh the domain the in let and out let are not in the output mesh as in picture 3. I have also tried to mesh half of domain structure and the other half unstructured but in the structured half the outlet is not in output mesh picture 2 and picture 4 is the output mesh in fluent. what is wrong with structured blocking mesh that does not include inlet/outlet in output mesh? I have made material point as fluid in every domain I wanted to mesh. Last edited by mehrzad; December 10, 2014 at 04:29. |
December 10, 2014, 04:14 |
mehrzad
Rep Power: 14 |
I have associated the block edges to the curves of outlet .the problem is solved
December 10, 2014, 18:07 |
Simon Pereira
Rep Power: 47 |
Sorry, I am not sure what you mean in your second post... In case the problem is not fixed:
This is most likely an issue with association between the block face and the surface. If you were relying on auto association (default which usually works), perhaps you have some duplicate surfaces and it is simply projecting to the wrong one. You can force it by associating face to surface. Pick the face and the part you want it to associate with.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 05:29 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
Problem with Output to .cfx5 mesh | Ben | CFX | 4 | January 24, 2008 17:47 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
