Home > Forums > ANSYS Meshing & Geometry
[ICEM] Y-block on curved surfaces
Like Tree3Likes
  • 1 Post By PSYMN
  • 1 Post By Far
  • 1 Post By PSYMN
Old   September 19, 2011, 02:18
Default Y-block on curved surfaces
Andrey
Ralen is on a distinguished road
Hi All.
How do I build the same Y-blocks as shown in the ICEM help?
ICEM Project http://www.sendspace.com/file/ygl9nw
Ralen is offline   Reply With Quote
Old   September 19, 2011, 08:18
AB
BrolY will become famous soon enough
Blocking -> Create Block -> From Vertices/faces
Select 3D as Dimension, Hexa as Block Type and then Quarter O-Grid
Have fun
BrolY is offline   Reply With Quote
Old   September 20, 2011, 03:45
Andrey
Have fun
Here's how it happened to one corner. Somewhere there was another grid.
Old   September 20, 2011, 05:41
AB
Before creating the Y block, you have to delete the previous one !
Another tip, once you have created your Y block, always go to Blocking -> Check Blocks -> Fix Inverted Block. Otherwise, you would have negative determinants.
Old   September 20, 2011, 07:05
Andrey
I remove all the blocks, creating a 3d box for all the geometry and divide it into 4 equal square blocks. I did not remove the block and create Quarter O-Grid on it, because I need / \ (upside down Y as in the image below), but not \ / (Y). Accordingly, I need external vertex, rather than internal.
Old   September 20, 2011, 07:35
AB
You have to remove that block and use the vertices of the remaining blocks to create your 1/4 O-grid.
Post the geometry here, I will have a look and show you the steps to create that Y block
Old   September 20, 2011, 07:45
Andrey
Geometry http://www.sendspace.com/file/3zmvok. ICEM Project is attached in the first post. I'm here about that if I remove the block, then lost two vertices at the corner. In total, four such blocks need to curved surfaces, and four for the vertical plane.
Old   September 20, 2011, 08:56
AB
I can't open solidwork file with my ICEM.
So please send a .stl file
Here is another tip :
1) show the VORFN part, and add the 3 blocks around the one where you want to create your Y block to your fluid part
2) delete the block where you want to create the Y block
3) create your Y block
4) delete the 3 blocks
5) fix inverted block
It should work
Old   September 20, 2011, 10:28
Andrey
STL file. This is part of the diffuser as shown in the first message. I'm just trying to build a grid separately.
Old   September 20, 2011, 13:14
Retired from CFD Online
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
I think the problem in the image that showed overlapping mesh was actually the lower surface projected edges projecting to the top surfaces instead of the lower surfaces... Run a cut plane thru the other direction to be sure...
Ralen likes this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   September 21, 2011, 03:54
AB
Ok here we go:
1) Create the 2 cuts as you did before
2) Create an o-grid for all of them
3) Add another split in the o-grid
Your blocking should be like the one at the picture 1
4) Merge the vertices 1 with 2 and 3 with 4 (cf. picture 2)
5) Associate curves with edges
Old   September 21, 2011, 04:35
Andrey
Ok here we go:
And what this mesh is different from mine, shown in the first post? Do not solve the main problem: the sharp angles of triangular surface mesh is bad.
Old   September 21, 2011, 04:44
AB
oh, you want to improve the quality of your mesh ??
In your 1st post, you asked how to create the same mesh than the one shown in the pictures ...
So, I guess you try to improve this mesh by creating a Y block ?
Old   September 21, 2011, 06:26
Andrey
Sorry. In the first post four pictures: the first three of them made by me, and the last of the ICEM CFD HELP. I want to get a mesh like the last picture. But in my case I need to do 8 Y-blocks.
Old   April 4, 2012, 05:05
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
I know this is the solved problem, but it may help others who have similar problem. That is how to create Quarter O-grid for wedge block with single click
http://www.youtube.com/watch?v=92vSc...ature=youtu.be
Ralen likes this.
Far is offline   Reply With Quote
Old   September 20, 2012, 17:48
PSYMN's Avatar
Simon Pereira
Thanks for taking the time to make this helpful video.
If you (or anyone else) would like to share your demo vids with a larger audience, please email your youtu.be link to "social@ansys.com" and tell them they are welcome to post it in the user generated content favorites list of the ANSYS TechTips YouTube channel. The URL for this channel is http://www.youtube.com/ANSYSTechTips. If it is a technical demo, ask them to put it under tech tips. ANSYS can hit the "like" button and add it to their favorites so it shows up on the ANSYS channel. Of course, there is no guarantee they will like your video ;^).
One other thing, please make sure that the description of your video clearly states what the demo shows so that people can find the right ones...
Far likes this.
Thread Tools
Trackbacks are On
Icem Mesh to Foam jphandrigan OpenFOAM Mesh Utilities 4 March 9, 2010 03:58
Sampling curved surfaces sega OpenFOAM Post-Processing 0 July 12, 2009 11:40
curved surfaces in airpak francesco montagnani FLUENT 2 April 3, 2004 03:08
Normal Vector on Curved Surfaces Karl FLUENT 0 July 2, 2001 04:35
Law of the wall on curved surfaces Rasputin Main CFD Forum 3 November 2, 1998 10:28
