[ICEM] Non manifold boundary error
Like Tree1Likes
  • 1 Post By PSYMN
Old   September 19, 2011, 03:43
Default Non manifold boundary error
AB
BrolY will become famous soon enough
My project is a kind of sphere. To block that geometry, I creat the blocking for only a quarter of the geometry, then I extrude the faces of the blocking with the option "extrude blocks along a curve".
At the boundary faces, I have tis minor error which occurs all the time : "non-manifold boundary at node xx" (xx represents all the nodes on the boundary face) and the extrude fails. I had the same errors when I try to create an o-grid at the 2 blocks which are at the junction of the 2 boundary faces of the blocking.
Does anyone know where this error comes from, and how to fix/avoid it ?
Thanks,
BrolY is offline   Reply With Quote
Old   September 20, 2011, 12:49
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Sorry, I guess I don't understand how you extrude to capture a sphere... Maybe some images would help me understand what is going wrong here and how to fix it...
But for definitions... A manifold node is one that is surrounded by a single loop of nodes. A non-manifold node is one that is surrounded by more than one loop of nodes...
XJTH likes this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   September 21, 2011, 04:06
AB
There is an hole in the middle of the sphere, and there are also holes between the sphere and the middle hole (look at the attached picture for a better understanding )
So I created a blocking for a quater of this sphere, and use the function "extrude along a curve" to block the other parts of the sphere. But sometimes, this function didn't work because of "the non manifold boundary at node xx".
I finally succeeded in extruding the blocking by creating curves instead of using the sphere curves.
Old   September 21, 2011, 09:20
PSYMN's Avatar
Simon Pereira
I still don't get it... I would probably have used a quarter Ogrid (like in the sphere cube tutorial), but I am glad you figured out a way that worked for you.
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
