September 26, 2011, 07:07 |
Using Pointwise for FLUENT meshing
Mahak
Rep Power: 15 |
Hi all,
I am trying to export mesh from pointwise in .cas format and trying to read it in tecplot just to check the mesh validity because my unstructured solver preprocessor did not accept it. Tecplot also gave me error: 'End-of-file while skipping section 84044028.' I have used pointwise in past in the same way, but this problem is new. Could someone help please with this peculiar error please? Many Thanks M |
September 26, 2011, 16:55 |
John Chawner
Rep Power: 18 |
Hello Mahak:
Unfortunately, I don't know what that Tecplot error message means. In order to figure out what's going on with your Fluent .cas file we'll need to get a lot more information. My suggestion is to contact our technical support engineers at support@pointwise.com and tell them about the error, your mesh, and what version of Pointwise you're running.
John Chawner / jrc@pointwise.com / www.pointwise.com Blog: http://blog.pointwise.com/ on Twitter: @jchawner |
September 27, 2011, 09:48 |
Mahak
Rep Power: 15 |
Hi John,
Thanks for the reply. Do you think beacuse of lack of memory its not able to write out the file properly? Then I can try it on a machine with higher RAM. Normally Pointwise gives an error message if that is happening. Thanks M |
September 27, 2011, 10:26 |
John Chawner
Rep Power: 18 |
Without knowing how large your grid is or how much memory your computer has it's hard to say but certainly trying on a machine with more RAM won't hurt.
[Commercial meshers] Native OpenFOAM interface in Pointwise | cnsidero | OpenFOAM Meshing & Mesh Conversion | 41 | May 20, 2012 18:30 |
Native OpenFOAM interface in Pointwise | Chris Sideroff | Main CFD Forum | 0 | January 16, 2009 12:37 |
Meshing locks workbench window. | andy2o | CFX | 0 | February 1, 2008 05:01 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
