Home > Forums > ANSYS Meshing & Geometry
[ANSYS Meshing] Submodeling
Old   September 26, 2011, 12:17
Default Submodeling
Enio Carpi
MrFEA is on a distinguished road
Hi Folks
I'm trying to do sub modeling in ANSYS WB. The sub modeling routine "insists" in loading a .db file from a \_ProjectScratch\ directory (which I couldn't find) even if I set the actual file path, after making sure it is there.
Any ideas?
MrFEA is offline   Reply With Quote
Old   March 28, 2013, 15:47
BahaZero is on a distinguished road
I have been wrestling this issue for quite some time. It appears that the actual run directory within the _ProjectScratch folder comes with a randomly generated name.
I used to use ".\" to access current directory but that does not work any more. I've also tried retrieving the home directory path with *get without success either.
For what possible reason that this folder name needs to be randomly generated I could only guess. If someone can figure out a solution or have some ideas that I could try, it would be much appreciated.
BahaZero is offline   Reply With Quote
ansys sub modeling
Thread Tools
Trackbacks are On
