[ANSYS Meshing] ANSYS Meshing hangs at "Preparing to model boundary for part" |
September 27, 2011, 14:08 |
jonathan
Depending on the model and the types of mesh controls I have, I've noticed that ANSYS meshing can get hung up in the "Preparing to model boundary for part" process. I noticed that the length of time that Meshing spends during this process can be quite variable and I have not been able to pinpoint exactly what causes delays.
I've had to wait for sometimes over an hour before the Mesher moves forward. I've noticed that some information is output to the console during this process and it seems that ANSYS Meshing gets up during this particular event: Constructing BGrid for the current proximity SF. ... constructing a search tree ... attaching a bgrid ... computing proximity Does anybody know what exactly is happening during this phase and if there is a way to speed it up. Thanks, Jonathan |
September 28, 2011, 12:38 |
jonathan
So after doing some testing it appears that any time you make an update to the geometry and then update that geometry information in ANSYS Meshing. The meshing process seems to "reset" itself or something of that sort.
Does someone know if ANSYS Meshing stores some type of information that helps the "preparing to model boundary for part" phase go faster upon subsequent meshing calls? I hope all of this makes sense. I'm not sure if I'm doing a good job explaining the issue. |
September 29, 2011, 13:42 |
jonathan
To hopefully help clarify the issue I am having, I have attached a screenshot showing the message output that ANSYS Meshing shows in a dialog box and output to the console. The message dialog only says "preparing to model boundary for part", but more information is output to the console during this operation. It appears that a Bgrid (whatever that is) is being created for the proximity SF (whatever that is also!) then it trys to compute the proximity but gets hung up. I wait for over an hour before finally stopping. In the past when I used to mesh the exact same part, it would breeze right through this process and finish the entire mesh in under 10 mins. Again, I made changes to the other parts in the geometry but not to the part that I am trying to currently mesh. Also, I checked and the mesh controls are identical as before.
Anyway, if anybody can provide any guidance what-so-ever I would greatly appreciate it. This issue is driving me nuts because I don't know what ANSYS Meshing is having trouble with so I have no idea about how to fix the problem. If I had one suggestion it would be to provide more information to the user about processes, issues, and errors. To the user. This has always been a gripe of mine about ANSYS Meshing. |
October 4, 2011, 17:26 |
jonathan
I have attached a screenshot showing an error I get when I import the geometry as a parasolid. The error states "face-face inconsistency" could this be the reason why the mesher is taking so long for this geometry?
Does anybody know how to repair this? Thanks, Jonathan |
January 28, 2012, 11:24 |
manoj
i an doing air flow analysis of turbine ventilator n i am also getting similar kind of face-face inconsistency error
January 28, 2012, 13:50 |
Ali
I experienced the hang-up situation so many times. whenever I use both curvature and proximity based refinement/size, Ansys Meshing hangs. If I use only curvature it works fine.
I suggest try with Curvature only option, ur problem may be solved. |
January 29, 2012, 02:59 |
manoj
thanks for ur suggestion but error is there in design modeller i.e when i import the geometry. so i cannot resolve it in meshing as meshing will not start unless i resolve this error
January 29, 2012, 04:37 |
ALi
you didn't mention the "error". will you please?
I usually face this problem during mesh generation with curvature+proximity option ON. |
January 29, 2012, 05:03 |
manoj
i have created the model of turbine ventilator using proe and saved it as .iges. now when i import this geometry in design modeler in ansys at few of the faces i get face-face inconsistency error and so the model is not validated, i cant do meshing unless i validate the model in design modeler.
January 29, 2012, 14:33 |
manoj
i have created the model of turbine ventilator using proe and saved it as .iges. now when i import this geometry in design modeler in ansys at few of the faces i get face-face inconsistency error and so the model is not validated, i cant do meshing unless i validate the model in design modeler.[ATTACH]Untitled.jpg
February 2, 2012, 04:40 |
#11 |
manoj
finally i have solved my face face inconsistency problem. it arises due to miss match of tolerance value of modeling software and analysis software.i had modeled my part i.e. turbine ventilator in Proe and analysed in Ansys. default tolerance in Proe is .012 mm and that in ansys is .001 mm so i changed tolerance in proe to .0001 mm and the problem is resolved
June 11, 2012, 17:15 |
#12 | |
ARUN V
Uploaded with ImageShack.us I am facing a similar problem in external flow over a car . could you please tell me how can i change tolerance value in ANSYS v13? nothing is mentioned about tolerance in details view of import I am importing a solidworks model, so can anyone tell me how to change the default tolerance in SW as in proE ?? |
June 12, 2012, 01:55 |
change tolerance in solidworks and ansys
#13 |
manoj
Solidworks
The Dimension Tolerance dialog box is accessible by clicking Tolerance in Tools, Options, Document Properties, Dimensions Options. Ansys Tolerance can be changed while meshing the component, there is option to do so in meshing dialog box . |
Evaporation model in ansys Fluent 12.1 | oldisbest | Fluent UDF and Scheme Programming | 12 | March 26, 2020 09:11 |
CFX13 Post Periodic interface | EtaEta | CFX | 7 | December 8, 2011 17:15 |
transient simulation of a rotating rectangle | icesniffer | CFX | 1 | August 8, 2009 07:25 |
boundary condition_vof model | garima chaudhary | FLUENT | 0 | October 9, 2007 02:08 |
