-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   Problem with segment surface and meshing (http://www.cfd-online.com/Forums/ansys-meshing/93334-problem-segment-surface-meshing.html)
Silmaril October 12, 2011 05:05
I work with ICEM. I need to make several cylindrical holes in a spherical surface, so I have intersected the sphere with the cylinders obtaining the intersecting curves. After that I segment the sphere through the curves. At that point some of the segmentations get wrong: or didn't work at all or segment the surfaces but not exactly along the curve, with some little errors.
How can I solve this problem? is there some setting that influence the segmentation?
The problem rises when I have to mesh the model: in the holes that didn't segment exactly along the curve (even if the geometric difference should be neglected) the boundary curve itself was segmented in many sub-curves (some of them very tiny).
When the code try to get the tetra mesh, many highly deformed triangles are formed near such curves (with the edge on the sub-curve very small while the others much bigger, taking the imposed mesh size from the surrounding surface).
How can I fix this problem? even if I cannot fix the segment issue, is there a way to impose the meshing so that I can make the code to forget about those tiny sub-curves?
Thanks for the help
Silmaril
PSYMN October 13, 2011 16:42
Tri-tolerance
A number of the geometry commands (such as create intersection curve or segment by curve) are very sensitive to the tri-tolerance of the model. I suggest refining the tri-tolerance and then trying again...
Search the Help for more info...
Best regards,
Simon
