Home > Forums > ANSYS Meshing & Geometry
[ICEM] hybrid mesh of tangential inlet
Like Tree4Likes
Old   October 26, 2011, 08:38
arjun
arjun3020 is on a distinguished road
1. Hi Michal, but how to avoid that bad elements. is there any other way to mesh this? that's why i go for hybrid mesh but still it is not working. i am sending you the hybrid mesh of project. you have to create hybrid mesh because file size is large. load hex mesh from blocking. and just form hybrid mesh and check mesh at inlet. it is bad. please have a look and help me in the same.
2. Hi Broly, i will Try your suggestions. thank you for your help.
arjun3020 is offline   Reply With Quote
Old   October 26, 2011, 08:45
arjun
also refer images provided.
thanks.
Old   October 26, 2011, 08:47
Michal
Twix is on a distinguished road
Good idea Broly, I haven't thought about that in this way.
Regards
Twix is offline   Reply With Quote
Old   October 26, 2011, 08:56
Michal
Arjun I think that method posted by Broly will be the best way to avoid bad elements.
Regards
Old   October 26, 2011, 09:26
arjun
Michal & Broly, it is best method for given geometry. but what to do if geometry is having long cylinder and tangential inlet. see attachment.
is it possible to extrude blocks within remaining areas,
(Cone shape of the cyclone)
Old   October 26, 2011, 09:38
AB
BrolY will become famous soon enough
Blocking -> Create Block -> Extrude Face
Then Method : Extrude Along Curve
Then Assign your new edges
And good to go
BrolY is offline   Reply With Quote
Old   October 26, 2011, 09:59
arjun
Hi Broly, Thank you. i know the procedure to extrude the block. my question is regarding quality after extruding the block, i have to associate the remaining two edges (out of eight edges) to curve (arc of cylinder). so quality again decreases. simply i mean that the modifications maid by you are not going to help in this case.
See the attached image.
Old   October 26, 2011, 10:12
arjun
Hi, if possible please tell me about hybrid mesh. refer reply number 12. of this thread.
Old   October 26, 2011, 10:24
AB
I think you wont be able to avoid those bad elements.
You can't use anymore the trick I've done in my last project because you need that cylindral shape for the extrude.
I haven't done hybrid mesh with ICEM, but I will have a look
Old   October 26, 2011, 10:32
arjun
ok thank you so much. but i have one question,
is there any bad effect on analysis of these bad elements?
i will going to use FLUENT for flow distribution and heat transfer analysis.
Old   October 27, 2011, 01:36
arjun
i am sending you the quality report. is it ok for analysis in FLUENT?
Min = -0.183558, max = 1, mean = 0.926004745677
498559 elements with the "Quality" diagnostic
Histogram of Quality values
0.95 -> 1.0 : 209980 (42.117%)
0.9 -> 0.95 : 173359 (34.772%)
0.85 -> 0.9 : 63403 (12.717%)
0.8 -> 0.85 : 29634 (5.944%)
0.75 -> 0.8 : 13409 (2.690%)
0.7 -> 0.75 : 5631 (1.129%)
0.65 -> 0.7 : 1231 (0.247%)
0.6 -> 0.65 : 640 (0.128%)
0.55 -> 0.6 : 215 (0.043%)
0.5 -> 0.55 : 121 (0.024%)
0.45 -> 0.5 : 66 (0.013%)
0.4 -> 0.45 : 129 (0.026%)
0.35 -> 0.4 : 126 (0.025%)
0.3 -> 0.35 : 191 (0.038%)
0.25 -> 0.3 : 207 (0.042%)
0.2 -> 0.25 : 212 (0.043%)
0.15 -> 0.2 : 2 (0.000%)
0.1 -> 0.15 : 0 (0.000%)
0.05 -> 0.1 : 1 (0.000%)
0.0 -> 0.05 : 2 (0.000%)
Old   October 27, 2011, 03:32
AB
You should ask this question in the Fluent part of the forum.
I have never used Fluent, so I can't tell you. But from my experience on other CFD codes, it could cause convergence troubles, especially if those elements are located in an area of interest.
Old   October 28, 2011, 02:23
arjun
HI, Michal & broly,
i am sending my cyclone project. i have made few modifications in geometry at inlet. please go through it. share your views on it. will these modifications affect my analysis.?
Evg700 likes this.
Old   October 28, 2011, 04:44
Michal
Hi
I have never simulate cyclone so I canít tell is that kind of modification affect on simulation results but changes are small so probably impact will be negligible. However, you extruded inlet so if velocity profile is important you have to take it to account.
Regards
BrolY likes this.
Thread Tools
Trackbacks are On
Fluent converting 'wall' to 'interior' BC for hybrid mesh DarrenC FLUENT 6 November 6, 2014 06:00
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
How to control the Inlet block mesh in turbogrid Mickel CFX 0 June 21, 2006 20:21
hybrid mesh around a stator Michele Cagna FLUENT 2 October 25, 2000 09:12
