[ICEM] Volume Orientation Issue
Old   October 23, 2011, 16:53
Default Volume Orientation Issue
Liander is on a distinguished road
Dear All,
I am meshing a 3D S-Duct through Icem and have used the strategy that you can see in the picture (basically everything, including the farfield, is meshed through a series of O-Grids that are contained within each other).
My problem is that while everything is fine when I try to generate the mesh with very high values for the boundary layer elements, as soon as I set an appropriate y+ value the mesh has orientation issues.
In the picture you can see the axialsymmetric cowl and,despite the blocking being symmetric, the apparently random distribution of volume inverted elements.
I have tried changing the boundary layer growth ratio, tried changing the block size and shape and tried varying number of elements along the defining curves (where if I decrease them in number, the issue seems to improve).
Does anyone know what causes the problem and how I can resolve it?
Thank you!
Liander is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
