Right approach for meshing of square with circle
Old   October 24, 2011, 22:04
Default Right approach for meshing of square with circle
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Dear ICEM fellows
I have just started to learn the ICEM CFD. I trid to mesh the square with inside circle (see attached Figs.).
But the problem I have is that I have to specify the edge mesh points for each of the four diagonal edges. Even I turned on the copy parameters to all parallel edge. Is there any continuity problem for four blocks, in other words are these blocks connected to each other? if no, please tell me my mistake and appropriate way to handle this.
Far is offline   Reply With Quote
Old   October 24, 2011, 22:05
Far
Sijal
remaining Figures ..........
Old   October 25, 2011, 09:32
anonymous
Doginal is on a distinguished road
Hello Far
I do not have much experience with ICEM CFD but hopefully i can help. I think what you have done is fine. The blocks are there to guide the mesh generation, the mesh is not "separated" or anything like that between blocks if that is what you mean.
In fact, ICEM with not let you make uneven mesh between blocks. meaning in 1 block you cannot have 100 radial divisions then in an adjacent block have only 75 radial divisions.
The only real "issue" i can see with your mesh is that the corners of the blocks associated with the circle are not evenly distributed which can distort the mesh.
Another approach that you can consider which would make developing the blocks much easier is to use an "O-grid". Rather than dividing the mesh into 9 blocks and deleting and moving them around. A simple o-grid cut will make this exact block system in 1 step. Then you simply associate the outside edges to outside curves, associate the inside edges to inside curves. Snap the vertices to place (can be done while associating the inside edges). Then delete the inside block.
Thank You,
DM
Doginal is offline   Reply With Quote
Old   October 25, 2011, 10:18
Far
Sijal
wow, you just did the magic. Now I feel that my approach was not good enough, what you have suggested is much better way to do the same thing in very few steps.
Thank-you.
Rotating square on icoFoam cavity McCarra OpenFOAM Programming & Development 1 January 14, 2011 09:23
[ICEM] Null pointer error? Mudblood ANSYS Meshing & Geometry 6 June 1, 2010 15:30
Subtraction of a circle from a rectangle,Gambit engahmed ANSYS Meshing & Geometry 2 May 17, 2010 01:08
square tube vs round pipe Eric Main CFD Forum 4 September 7, 2007 00:53
How to mesh a circle by Gambit? Zhengcai Ye FLUENT 5 March 24, 2006 01:04
