Home > Forums > ANSYS Meshing & Geometry
[ICEM] Unstructured 3d blade grid
Old   October 31, 2011, 13:42
Default Unstructured 3d blade grid
Papis
papis is on a distinguished road
Hi all,
I am trying to make an unstructured tetrahedron mesh of a rotating blade.
The problem I need to simulate is the Caradonna rotor which is a 2 bladed helicopter rotor.
As you can see from the pictured below i have generated an mesh with periodic boundaries.My main problem is the generation of grid ON the blade
As you can see the surface mesh doesn't actually fits the surface of the blade(Not all nodes of boundary faces are on the airfoil surface) which of course is problematic.
At first I thought it might be resolution but when doing hexagonal grids(with blocking for example) the surface is fitted very nicely even at low resolutions.
If anyone could point me to the right direction to understand this issue I would be grateful.
[IMG]file:///home/papis/Desktop/screen1.jpg[/IMG]
[IMG]file:///home/papis/Desktop/screen2.jpg[/IMG]
P.S. I have created only one body (the region between the blade and the outer boundary,since i do not need grid inside the blade)
Thanks a lot
papis is offline   Reply With Quote
Old   November 1, 2011, 07:18
Papis
Is it possible that surface meshes should be generated first?
Old   November 1, 2011, 12:54
Ludvik Lanicek
Ludvik is on a distinguished road
Try decrease "Edge criterion" parameters from 0.2 to 0.005 (Global Mesh Parameters > Volume Meshing (Octree) ) and/or try to use "Thin Cuts".
Ludvik is offline   Reply With Quote
Old   November 1, 2011, 14:08
Papis
Yeap this improved things.Thanks a lot for you help.I read the help about the edge criterion option and it wrote " value 0.2 is adequate for most cases.".This is very misleading since 0.2 can't prescribe the surface of naca0012 blade.
Anyway's Thank a lot for your reply Ludvik
Thread Tools
Trackbacks are On
Help! Validity of unstructured grid on S809 airfoil didiean FLUENT 11 April 3, 2011 02:10
2D unstructured Grid prapanj Main CFD Forum 4 March 15, 2008 18:01
unstructured mesh grid independence for Fluent Shane Schouten FLUENT 0 October 11, 2006 16:50
to Identify unstructured grid and structrued grid harry Main CFD Forum 4 February 17, 2006 03:10
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
