Using Blocking with ICEM (infinite blocking lines appeared)
5 Attachment(s)
I am trying to mesh with ICEM a rectangular domain of a flow over a plate using 2D Planar Blocking (Figure3) method. When I use Blocking my 2D domain is not closed. The upper and lower blocking lines continue on the right and left sides to infinity ??? The simple geometry is below. I think that it is an environment setting (Picture 2) problem but I don't know which one. In picture5, VORFN is activated. Any suggestions. |
Solved
It was the tolerance which were too big. I reduced the tolerances in Menu -> Settings -> Model
This may be caused due to some entity placed at some large distance from the main object.
| All times are GMT -4. The time now is 10:47. |
