Combining Turbogrid and ICEM
I'm looking to model an open rotor blade (so twisted from hub to tip) whilst fully resolving the boundary layer. Do any of you know how feasbible it would be to create a structured grid around the blade in Turbogrid, then export the mesh the into ICEM. Then build an unstructured mesh in ICEM, and merge the two? The plan would be to have fully strucutred mesh around the blade with a 50% span tip clearence (created in Turbogrid), then have unstrucutred mesh (created in ICEM) completing the domain out to the radial farifield. Any other possible solutions would be welcome too. Thanks Tom |
If you want to create interface between upper portion of tip clearance (half tip clearance gap and casing) with other half portion of tip clearance (with complete blade blade, hub) then there is no need to go to ICEM. This can be done easily in CFX Pre. So in other words
1. create mesh of blade with half tip clearance including hub and blade in turbogrid 2. Create mesh of other half tip clearance in ICEM 3. Take both meshes to CFX Pre and create interface between them (GGI) |
Ah I see what you mean. Thanks for the suggestion.
I am hoping to use Fluent, but in theory could switch to CFX if needed. However, I chose 50 % span tip clearence as thats as large as I could create in Turbogrid. For the open rotor simulation, looking to have farfield boundary at least 6 chords in the radial (vertical along blade) direction. The reasoning would be, a good quality structured grid created in TG to resolve the local flow features around the blade (wake and vortices etc) then unstructured to extend out to the far-field to resemble the unducted (open rotor) flow physics. |
No need to use CFX. Can be combined in Fluent as well
Ah ok, do you think doing the merging of the two meshes in ICEM would produce any difference in quality?
The GGI in CFX-pre does look quite handy. I'm just concerned about having interface problems between the two meshes. And ensuring complete periodicity between the two. In the long run, this method should save time though. |
Ah that makes sense.
But I was planning on having the entire domian as stationary. And setting the fluid to rotate. Will look into having rot and stat domains. Which in theory makes more sense. I'd presume Fluent has similar capabilities with GGI to CFX. Thanks for the continued feedback, Its very helpful! |
Ye, but you can also have the entire fluid domain rotating, and solve in the absolute frame. This avoids having high relative velocities at the boundaries.
But, having an inner rotating domain and stationary outer, will also have same effect I believe. |
Make sure to put the
1. For Fluent : Outer domain boundaries (except inlet and outlet) with zero rpm in absolute reference frame with appropriate axis of rotation. 2. For CFX : Outer domain boundaries (except inlet and outlet) as counter rotating wall |
Dear Far
I need to Mesh inside my blade. I am creating my grid with turbogrid. but I have problem to creat the mesh of blade. I am exporting the Mesh of Turbogrid to Gambit to do that work. Also because of the grid at the tip, I can not export the grid to pointwise. Could you please give me some suggestion? Best Mahdi |
do you still need help?
Thanks for reply. I have created the tip clearnce in Bladegen and exported in pointwise to make the grid. but still I have problem. If there would be a way for fast creation of Rotor grid and also a grid inside a blade it will be really helpful. But I need a Grid which is generated ( for example turbogrid ) to be readable in Pointwise. I nead to creat two block very thin along the surface of the blade to test a boundary layer control technique. In Fact my future problem will also be refining the mesh around those blocks because of the imposed grid scale of physiscs of the problem. If you could give some advise i will grateful best Mahdi |
Can I use turbogrid then import it to fluent and then combine it with the volute in fluent?
Or I have already attached the 2 meshes into cfx but I cannot define the interfaces! Any help in cfx? |
https://www.google.com.eg/?gfe_rd=cr...shes+in+fluent |
