[ICEM] Hexahedral elements are 2D !!!
Old   November 14, 2011, 18:35
Default Hexahedral elements are 2D !!!
Kalyan
kalyangoparaju is on a distinguished road
I am trying to mesh a wing with NACA 0012 section with a blunt trailing edge. I was able to go through the blocking process properly building an o-grid and deleting the unnecessary block ( wing block). The blocking when I look at it visually looks pretty good but when I check the quality, it gives me very very bad quality even negative values.
When I see the bad cells, they look like 3D cells but are on the same face so essentially, ICEM is trying to put 3d cells on a face. hence the aspect ratio and the skewness is screwed giving a very bad quality. Can someone help me in finding the problem.
I am attaching some pics of the mesh and the geometry.
Once I did the o grid around the airfoil, I associated the inner o-grid block to the airfoil so that there won't be any mesh inside the airfoil. I think I am missing some trick here since 3D wing should be relatively very easy to mesh with high quality.
Please
kalyangoparaju is offline   Reply With Quote
[ICEM] Hybrid mesh for 2D boundary layer Bigio ANSYS Meshing & Geometry 33 November 18, 2019 09:15
Penetrating elements in extruded mesh Michael P CFX 2 May 20, 2005 08:06
[Gmsh] Modified gmshToFoam to help import hexahedral and prism elements from Gmsh adorean OpenFOAM Meshing & Mesh Conversion 1 April 18, 2005 08:19
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
