-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] Hexahedral elements are 2D !!! (http://www.cfd-online.com/Forums/ansys-meshing/94400-hexahedral-elements-2d.html)
kalyangoparaju November 14, 2011 19:35
2 Attachment(s)
I am trying to mesh a wing with NACA 0012 section with a blunt trailing edge. I was able to go through the blocking process properly building an o-grid and deleting the unnecessary block ( wing block). The blocking when I look at it visually looks pretty good but when I check the quality, it gives me very very bad quality even negative values.
When I see the bad cells, they look like 3D cells but are on the same face so essentially, ICEM is trying to put 3d cells on a face. hence the aspect ratio and the skewness is screwed giving a very bad quality. Can someone help me in finding the problem.
I am attaching some pics of the mesh and the geometry.
Attachment 10051
Attachment 10052
Once I did the o grid around the airfoil, I associated the inner o-grid block to the airfoil so that there won't be any mesh inside the airfoil. I think I am missing some trick here since 3D wing should be relatively very easy to mesh with high quality.
Please
