-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ANSYS Meshing] Ansys Meshing Error on Generation (http://www.cfd-online.com/Forums/ansys-meshing/94464-ansys-meshing-error-generation.html)
resnik November 16, 2011 15:44
Hi guys,
Just learning CFD from Ansys Tutorials. When coming up to the Mesh Update on page 1-21 (Point 4), am getting an error "an inter-process communication error occured while communicating with the MESHER module." ... (Application: Project>Module). Any idea how to get around this.
I am using Ansys 13.0 (Magnitude) 64 bit version.
Thanks
Same geometry and tutorial steps work on a Ansys 13.0 (64 bit) academic version install in Uni. ...
raj.cfd November 16, 2011 19:29
It can be either license error ( between workbench, geometry/design modeler and meshing)or the way the software has been installed. Probably you can re-install . More-over check for the ansys software minimum requirements like hardware, OS , RAM etc.
Tac Zeidler July 15, 2015 07:26
I had the same problem.
The tutorial said to put 6e-3 for the element size, supposing you're in meter.
The fact is you're in millimeter by default.
Put 6 mm instead.
The mesh is really to big with 6e-3 mm and the problem is maybe associated to the available memory.
Sorry for the english, I'm french native.
Bye
