block and mesh pipe in pipe
i want to mesh a double pipe. In the inner piperflows the fluid in on direction and in the other pipe it flows in the opposite direction. Please have a look at the picture. In wanted to make 4 o-grids, so that I can associate them to the different diameters. The first o-grid has functioned. But the second wonīt work. There is the message. The o-grid was not successful. A minor internal error has occurred. You may continue to work but if problems arise they may be related to this error. Try using the check/fix function to fix the problem The following message was designed to aid developers fix the problem: no blocks marked After this I canīt see anymore the block i have marked before. He is disappered. I donīt know why. In which way would you make the blocks for this geometry? Thank you for your help. https://picasaweb.google.com/1088763...November172011 http://www.cfd-online.com/Forums/dat...AASUVORK5CYII=https://picasaweb.google.com/1088763...63633575963506https://picasaweb.google.com/1088763...63633575963506 http://www.cfd-online.com/Forums/dat...AASUVORK5CYII= |
I dont see your geometry/pictures. By the way, the geometry what I assume from your post looks simple and there should not be any problem in meshing it. Post the pictures as image files, only then I can give you the exact idea on meshing....
Can you tell me in which way I can post the picture. I donīt know how it works...
I have solved the Problem.
Thank you. |
