Problem in importing in fluent
i have made a design jus lyk an closed box...now have a prob that there is 1 plate inside the box and during importing fluent doesnt read that plate bcoz of 2D and 3D...
is there any way to change the plate in 3D design means my whole model is in green color that represent volume..but the plate color is ligt blue..that means its onlt a surface..hw could i change it into green color.. |
you can create your volume by sweeping your blue surface.
sorry max..didnt get ur point..the blue surface will not convert into volume bcoz its nt d close 1...its an open plate like a passage in the box. :confused:
yes but if you want your surface to have a depth (volume), then you need to sweep your face
http://my.fit.edu/itresources/manual...mg0205.htm#406 If you want to stay with your thin plate, then consider it as baffle. (just enforce gambit to define it as wall) |
