November 26, 2011, 13:18 |
2d parallel edges mesh problem
Rep Power: 18 |
I am trying to mesh two surfaces separated by a thin wall. How to avoid elements generated through the wall? Is it a tolerance issue?
cheers! |
November 28, 2011, 14:43 |
Simon Pereira
Rep Power: 47 |
Two ways...
1) You could use patch dependent surface meshing... 2) It looks like you are using patch independent surface meshing, if so, you could setup "thin cuts" between the parts of the two curves. (look for it in the help for details) Best regards, Simon
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
problem when converting mesh (made by ICEM) using fluentMeshToFoam | Forrest_Lei | OpenFOAM | 11 | October 16, 2009 06:28 |
problem related to mesh | naveen | CFX | 3 | March 25, 2006 08:47 |
