Problem with uniting volumes
1 Attachment(s)
Dear all,
I have got a problem with uniting two volumes (using Gambit) which I generated via “Sweep Faces” (see pic). If I try to unite them I always get an error message: “ACIS error 8030: inconsistent face-body relationships”. Is there any way how I can avoid this? Thanks a million in advance! WBR Lilly |
can you provide your dbs file? (delete the mesh)
Same problem in uniting volumes
Hi all,
I am facing a similar problem while uniting the volumes(in gambit) that are previously subtracted. The error message shows "ACIS error 8030: inconsistent face-body relationships". I want to unite all the volumes(all blades,volumes above and below the blades) and subtract it from another bigger volume(not in picture) Kindly help me to fix the issue....Thanx in advance :) |
be sure your volumes are fully intersected together.
you can unite volumes, one by one, and check which is giving you trouble |
Thanx for the suggestion once again.
The blades in my previous post were touching the top and bottom volumes. This time I extended them so that blades and the other two volumes intersect(uniting will anyway make them into one single volume). But even this time i got the same error message "ACIS error 8030: inconsistent face-body relationships". Another way: As i said there is another bigger volume which subtracts this entire geometry(after uniting). When I tried to first subtract just blades from this bigger volume was successful. But again while uniting resulted volume with top and bottom volumes, error appeared "ACIS error 8033: decision to delete intersection graph was incorrect". Please kindly help me. Thanx :) |
Subtracting volumes
Hi, did you figure out how to fix the problem? I am getting
"ACIS error 8033: decision to delete intersection graphs was incorrect" when I try to subtract volumes in gambit. |
