Home > Forums > ANSYS Meshing & Geometry
[GAMBIT] Cylinder with slots meshing
Old   December 14, 2011, 02:31
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
No, you only have to define your rotor domain (surface in 2d) as rigid body in the moving mesh panel.
But in Gambit you have to set 2 kinds of fluid domain: one for stator, and one for rotor, else you cannot pick the rotor domain.
So you need in gambit to define as BC:
-your inlet
-your outlet
-your 2 interfaces
-your 2 fluid domains
in Fluent:
-define the interfaces by picking the 2 edges (already defines in gambit)
-in moving mesh panel, just define the rotor domain as rigid body and give the right angular velocity
Maybe you need to create the surface from your fluid zone, check here: http://my.fit.edu/itresources/manual...876.htm#156597
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   December 18, 2011, 22:28
Kaushik
kaushik180587 is on a distinguished road
Please can u show me in the pic I attatched earlier,the explaination u gave above ..also i couldnt set rigid body when i was setting the bc for rotor..
kaushik180587 is offline   Reply With Quote
Old   December 19, 2011, 01:20
-mAx-'s Avatar
Maxime Perelli
use this tool for defining your 2 fluid domains:
http://my.fit.edu/itresources/manual...zone_cont_type
Old   December 19, 2011, 06:34
k_k
Kailash
k_k is on a distinguished road
The easiest and safest way to setup the Sliding Mesh simulation is to setup a MRF simulation first and begin the sliding mesh simulation after few iterations. Define the rotating volume as the MRF domain and specify the rotational velocity and axis. After few iterations, on the Text User Interface activate Grid>Modify zones>MRF-to-sliding mesh. This should identify neccesary interface and prepare the sliding mesh boundary conditions.
k_k is offline   Reply With Quote
Old   December 21, 2011, 20:38
kk
srini8156 is on a distinguished road
Even I tried doing this example..max/kk I wanted to ask if the rotor domain is given angular velocity..then how do you get the effect on actual rotor surface which is slotted,pls clarify... also can this animated?
srini8156 is offline   Reply With Quote
Old   January 13, 2012, 14:31
Far
Far's Avatar
Sijal Ahmed Memon (turboenginner@gmail.com)
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
This topic is still on?
Best Regards
Far
http://cfd-consultancy.webs.com/
Far is offline   Reply With Quote
Thread Tools
Trackbacks are On
meshing on cylinder fails ICEM potac ANSYS Meshing & Geometry 0 October 25, 2011 05:21
2D planar cylinder meshing problem saisanthoshm88 ANSYS Meshing & Geometry 15 December 27, 2010 11:14
[ICEM] (ICEM CFD) meshing over a cylinder vmlxb6 ANSYS Meshing & Geometry 6 August 11, 2010 14:37
Meshing inside a cylinder so that the edges contain more cells than the center Bertrand OpenFOAM Native Meshers: blockMesh 1 April 13, 2010 04:46
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
