[GAMBIT] I need a 2-d model meshing pump to calculat radial thrust around the impeller
Old   December 10, 2011, 19:29
Default I need a 2-d model meshing pump to calculat radial thrust around the impeller
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
I am try to draw this model in Gambit and meshing and exporting to Fluent
to define the pressure distribution and calculate the efficiency and radial thrust force Please note that the:
1-2-d model
2-steady state
Please help in detail
tareqkh is offline   Reply With Quote
Old   December 10, 2011, 19:50
Default plz help
tareqkh's Avatar
CFD
Hello friends,
I am a Master's student at University of Tripoli. My thesis is about Study of radial thrus force around the impeller in Centrifugal pump and I am new to CFD. Can anyone please help me out with how to design and mesh an impeller in Gambit, or can you suggest some tutorials which will be useful in doing so? I just want to know the procedure of creating an 2d pump.
Thanks.
Old   December 10, 2011, 20:00
Default teach me
tareqkh's Avatar
CFD
Can someone here please teach me how to create a 2d centrifugal pump from start to finish using Gambit 2.2.30 and Fluent 6.2.16?
I'll give you a reward worth USD100.
Old   December 11, 2011, 10:05
Far
Sijal
well CFD starts from geometry and then meshing and solution. You should be able to generate the geometry from the data you have shown here.
Old   December 11, 2011, 11:46
Default plz lets start
tareqkh's Avatar
CFD
thank u for ur kined response
so its a deal and we can start from now through email or youtube using a password between us
best regards
how to extract the components of radial and tangential velocities from pump impeller renyun0511 OpenFOAM Running, Solving & CFD 3 October 31, 2022 09:31
Centrifugal Pump Impeller design invincible328 Main CFD Forum 27 September 21, 2014 10:59
I need a 2-d model meshing pump to calculat radial thrust around the impeller tareqkh FLUENT 2 December 10, 2011 19:58
Axial Thrust in a Radial Turbine Amit Roghs CFX 3 May 31, 2010 16:47
turbulence model for water pump Marcio Main CFD Forum 4 September 3, 2003 09:35
