Home > Forums > ANSYS Meshing & Geometry
[ICEM] How to export points from ICEM to Fluent
Old   December 12, 2011, 10:57
Default How to export points from ICEM to Fluent
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Dear All,
I made a 3d mesh of a pipe in ICEM and want to track some point values via "monitors" in Fluent. Now I created points in ICEM and put each of them into a "part" with a different name. Back in Fluent none of these points appear in any "surfaces" box. How can I get single points from ICEM to fluent?
Thanks for any help!
RodriguezFatz is offline   Reply With Quote
Old   April 23, 2012, 13:05
Justin Flanders
MetalSupremacist is on a distinguished road
Originally Posted by RodriguezFatz View Post
Dear All,
Did you figure this out by chance? I'm trying to export surfaces to use in FLUENT as boundary conditions.
MetalSupremacist is offline   Reply With Quote
Old   April 23, 2012, 13:57
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
It's impossible to do that. Fluent won't read your points and curves. i tried before with a curve. i got help from Mr simon who forwarded my problem to a fluent expert.
See the thread below
Fluent skips parts i create in icem
Regards,
New to ICEM CFD, try this document --> https://goo.gl/NEbygB
Ali
diamondx is offline   Reply With Quote
Old   April 23, 2012, 14:59
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
This is is possible in ICEM.
However you cannot export the point and curves (3d) from ICEM to Fluent
Far is offline   Reply With Quote
Old   February 26, 2014, 16:59
Default export point workaround
Grant
grantom is on a distinguished road
I recently had to export a large set (100+) of geometry points from ICEM. A workaround that I found is to:
1) clear the log window
2)Use the point locator button (in the top toolbar) to select each point you want the coordinates for
3) the coordinates for each point show up in the log window as you click them. When you're done, save the log window to a file
grantom is offline   Reply With Quote
Thread Tools
Trackbacks are On
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 26 June 9, 2015 15:38
Cannot import ANY ICEM hex core into Fluent v6.3!! Robert Perry FLUENT 11 April 12, 2012 04:30
Export mesh from ICEM to Fluent 6.3 (3D) bigbang ANSYS 0 June 7, 2010 23:05
[ICEM] 2D mesh export to FLUENT Ed Kay ANSYS Meshing & Geometry 0 October 22, 2009 11:08
Exporting Meshes from ICEM to Fluent zi FLUENT 4 August 9, 2005 10:58
