can any one give a tutorial for a 2d centrifugal pump
can any one give a tutorial for a 2d centrifugal pump how to make a mesh and how to analysis in fluent from 0 to finsish plz help
can any one give a tutorial for a 2d centrifugal pump how to make a mesh and how to analysis in fluent from 0 to finsish plz help,,please send to keyhan_mec@yahoo.com
Centrifugal pump
Hello al
How to make a mesh between the mobile part ( Impeller) and the fixed part ( Volute) of a centrifugal pump 2D in Gambit . |
you have to "separate" both meshes. For that you only need to disconnect both volumes (stator and rotor), and apply interfaces.
Later you will be able to run moving mesh, and you will see that rotor mesh will rotate (but not stator) |
