[GAMBIT] is it possible to create this type of grid?
Like Tree2Likes
  • 1 Post By Far
  • 1 Post By BigBen
Old   January 4, 2012, 11:55
Default is it possible to create this type of grid?
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Hi all,
is it possible in Gambit to create this type of grid (attached picture)?If yes, how?
Thank you,
Daniele
ghost82 is offline   Reply With Quote
Old   January 4, 2012, 12:23
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
yes it can be done in gambit. but you need to make them in steps and then import into fluent and then create the interfaces. However this can be easily done in icem cfd by refining the domains by the factor of 2 and you have two nodes corresponding to one node to other side.
ghost82 likes this.
Far is offline   Reply With Quote
Old   January 4, 2012, 18:12
BigBen is on a distinguished road
I confirm, it can be easliy done in Gambit but as said, you need to disconnect faces where the mesh is not conformed in Gambit and create interface in Fluent.
I may have another possibility. I would rather do everythng in Fluent using the Adapt/Region/refine in 3 steps.
Firts of all, create your mesh in gambit with the coarser mesh and import in Fluent.
In Fluent
1-adapt/region select by coordinates or by mouse button all the region which is refined (all the upper rectangular even the more refined). Press "refine" it will multiply by two the mesh in this region.
2-3 do it again for the small square on the upper left and upper right.
Hope it will help
ghost82 likes this.
BigBen is offline   Reply With Quote
Old   January 4, 2012, 21:28
Far
Sijal
Yeah it is much better and easier method and does not require interfaces
Old   January 5, 2012, 10:07
ghost82's Avatar
Rick
In Fluent
Hope it will help
Thank you Bigben,
I knew that this could be done in fluent; however I was curious to know if that grid could be done directly in gambit.
Thank you all for replies.
Daniele
Old   February 3, 2012, 04:55
Davide
themeska is on a distinguished road
Hi everybody!
I think this is the thread i've been looking for...as you all said a local refinement is possible and even easier in Fluent, by using the Adapt panel...anyway, this wouldn't be the easiest way for my geometry, since it consists of buildings with different heights...
Everytime i try to vertically sweep the outer region (which is to time as coarse as the inner one), Gambit says it cannot sweep it...i think it's because of the different number of intervals between the inner and outer region...and maybe Gambit is not able to connect them, am i saying something wrong?
can anyone explain to me how to do that?
What i'd like to do is to impose in Fluent different BCs for the inlet flow (i mean, different roughness heights), using different values for the inner and outer region...
themeska is offline   Reply With Quote
Old   February 3, 2012, 10:03
Far
Sijal
In mapping you cannot just change the nodes on one edge, you should change the no of nodes on parallel edges, but if you to make the mesh shown in 1st post, then you need to create different regions and save in different files and keep the region which you want to mesh and delete all other. Then export the mesh from all these files and read them in Fluent with append command. Got it?
Old   February 3, 2012, 10:10
Davide
So, basically, what you're saying is that i should create as many meshes as the regions with different cells' sizes and then "put" them together in Fluent?
Thanks a lot for your fast reply, helped a lot!
Regards
Old   February 3, 2012, 10:22
Far
Sijal
yes and at the common boundaries specify interface as boundary condition.
You muest read first mesh and for other meshes you must use the append command.
compilation problem with "fvPatch::lookupPatchField" Ya_Squall2010 OpenFOAM Programming & Development 9 November 15, 2021 22:01
[Other] cgnsToFoam problems with "QUAD_4" cells lentschi OpenFOAM Meshing & Mesh Conversion 1 March 9, 2011 04:49
turbulent jet simulation antonio_ing OpenFOAM Running, Solving & CFD 5 September 16, 2010 02:31
Flow Around a Cylinder ronaldo OpenFOAM 5 September 18, 2009 08:13
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
