[Sponsors] | |||||
Daniele
Rep Power: 3 ![]() |
Hi all,
is it possible in Gambit to create this type of grid (attached picture)?If yes, how? Thank you, Daniele |
Far (turboenginner@gmail.com)
Rep Power: 14 ![]() |
yes it can be done in gambit. but you need to make them in steps and then import into fluent and then create the interfaces. However this can be easily done in icem cfd by refining the domains by the factor of 2 and you have two nodes corresponding to one node to other side.
Best Regards Far |
Rep Power: 2 ![]() |
I confirm, it can be easliy done in Gambit but as said, you need to disconnect faces where the mesh is not conformed in Gambit and create interface in Fluent.
I may have another possibility. I would rather do everythng in Fluent using the Adapt/Region/refine in 3 steps. Firts of all, create your mesh in gambit with the coarser mesh and import in Fluent. In Fluent 1-adapt/region select by coordinates or by mouse button all the region which is refined (all the upper rectangular even the more refined). Press "refine" it will multiply by two the mesh in this region. 2-3 do it again for the small square on the upper left and upper right. Hope it will help
#5 | |
Daniele
I knew that this could be done in fluent; however I was curious to know if that grid could be done directly in gambit. Thank you all for replies. Daniele |
Davide
Rep Power: 0 ![]() |
Hi everybody!
![]() I think this is the thread i've been looking for...as you all said a local refinement is possible and even easier in Fluent, by using the Adapt panel...anyway, this wouldn't be the easiest way for my geometry, since it consists of buildings with different heights... Everytime i try to vertically sweep the outer region (which is to time as coarse as the inner one), Gambit says it cannot sweep it...i think it's because of the different number of intervals between the inner and outer region...and maybe Gambit is not able to connect them, am i saying something wrong? ![]() can anyone explain to me how to do that? What i'd like to do is to impose in Fluent different BCs for the inlet flow (i mean, different roughness heights), using different values for the inner and outer region... |
#7 | |
Best Regards Far |
Davide
So, basically, what you're saying is that i should create as many meshes as the regions with different cells' sizes and then "put" them together in Fluent?
![]() Thanks a lot for your fast reply, helped a lot! Regards |
#9 |
yes and at the common boundaries specify interface as boundary condition.
You muest read first mesh and for other meshes you must use the append command.
Best Regards Far |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| cgnsToFoam problems with "QUAD_4" cells | lentschi | OpenFOAM Meshing & Mesh Conversion | 1 | March 9, 2011 04:49 |
| turbulent jet simulation | antonio_ing | OpenFOAM Running, Solving & CFD | 5 | September 16, 2010 02:31 |
| compilation problem with "fvPatch::lookupPatchField" | Ya_Squall2010 | OpenFOAM Programming & Development | 4 | May 25, 2010 09:29 |
| Flow Around a Cylinder | ronaldo | OpenFOAM | 5 | September 18, 2009 08:13 |
| Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 11:18 |
