[ICEM] icem build topology problem
Old   January 9, 2012, 06:48
Default icem build topology problem
thais_b is on a distinguished road
Hi!
I'm trying to build up a mesh around a 2d airfoil. I created the surface, the lines of the airfoil (it's a naca 0012 with trailing edge gap). However when i apply repair geometry> build diagnostic topology, icem creates some lines that make the mesh does not respect the airfoil boundaries. I've tried patch dependent and independent.
Anyone knows what is this?
Thanks in advance!
thais_b is offline   Reply With Quote
Old   January 9, 2012, 07:08
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
pictures are not clear.
Far is offline   Reply With Quote
Old   January 9, 2012, 08:06
I'm sorry.
Thanks for you interest, Far!
The problem persists even if i increase the number of elements around the airfoil.
Old   January 9, 2012, 08:43
Far
Sijal
do you want to create unstructured mesh or interested in nice structured mesh with well resolved boundary layer?
Old   January 9, 2012, 09:40
Actually i'm trying to work with unstructured mesh + prism layers.
When Icem did not respect the airfoil, i used to correct it manually, editing the mesh. But the prism is constructed based on the built topology, so it does not work anymore.
I'm doing some research with icing accretions in airfoils, so unstructured mesh seems a good approach for that.
But some other ideas are welcome!
Thanks
Old   January 10, 2012, 09:53
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
So you want a flat trailing edge?
Just make sure that your Build topo tolerance is smaller than your trailing edge thickness. Then you will get points on both the top and bottom of the trailing edge.
As for the second set of pics, it looks like the surface is not aligned with the curves, but that is just a display thing. If you want to clean it up, you can go into settings => Model and reduce the triangulation tolerance by an order of magnitude.
Best regards,
Simon
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   January 19, 2012, 13:01
Thank you so much Simon.
It worked perfectly!
Thaís
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
problem exporting from icem to fluent jc_muaddib FLUENT 1 June 16, 2010 04:16
[ICEM] Problem with ICEM generated Mesh geothokar ANSYS Meshing & Geometry 3 May 11, 2009 13:26
Icem Cfd To Cfx B.C. Problem Kordou CFX 4 July 17, 2008 12:49
build earth problem stk Phoenics 1 March 23, 2004 10:02
