Far |
January 12, 2012 07:29 |
you can ask ANSYS, pointwise and gridpro (many other there also) for evaluation license for few months. Once you go through them, then you can decide which software to purchase for future use. I strongly recommend you to get the some test cases done at your institute as well as some difficult problems to be done by vendors of these codes.
If you are working on Fluent then I suggest you to consider the workbench option, which help you setup the problem very easily and also has the option to parametric and update geometry easily.
