[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry |
March 1, 2011, 03:21 |
Mazhar
Rep Power: 15 |
i hav developed a geometry in PRO/E, and extracted only the fluid path by cut from option avaliable in pro/e, n exported in gambit as part file.
inlet complex geometry details: liquid flow through a pipe- liquid inlet and flowing through an annular space ; then comes in full pipe flow; then passes through orifice plate; then through straight rods (heating source) placed in path of liquid; then again flow out by passing through annular space. how i can mesh this pipe ? is it possible to do volume mesh as one volume? i hav tried by dividing the whole pipe in 15 small volumes in pro/e and then assembled it as the original pipe design, but in fluent the faces of volumes are consider as wall so information from one volume is not transfering to another b/c of wall in b/w 2 volumes. tell me how i can mesh that complex pipe in gambit Last edited by mazhar1613; March 14, 2011 at 04:38. |
gambit-pipe flow |
[GAMBIT] Trouble meshing complex VOF geometry | RPJones | ANSYS Meshing & Geometry | 2 | February 14, 2011 18:54 |
Disturbed flow field at outlet boundary (Multiphase flow through pipe) | Michiel | CFX | 17 | April 21, 2010 10:14 |
gambit meshing for the flow passing cylinder | iilw1314 | Main CFD Forum | 5 | April 11, 2010 19:28 |
Meshing difficulty in Gambit on a complex model | Peter | FLUENT | 1 | July 16, 2008 15:59 |
meshing geometry in gambit | soundar | FLUENT | 1 | January 7, 2005 02:59 |
