Home > Forums > ANSYS Meshing & Geometry
[ANSYS Meshing] Can someone help with that Mesh???
Old   January 11, 2012, 13:21
Default Can someone help with that Mesh???
Ofir Laor
OfirLaor is on a distinguished road
Unsuccessfully, Iím trying to make FLUENT to accept my MESH file (in ANSYS WorkBench), and Iím quite stuck with itÖ
Iím trying to simulate the 2D flow over the shape that I attached to this thread. Somehow, no matter which shape of domain Iím using, when trying to do the SETUP, and updating the MESH, I get this message over and over again- ďThe mesh file exporter failed during translationÖď
I tried splitting the domain into different areas and Map it, I tried Sizing controlsÖ But still, nothingÖ
If anyone have a good idea - Iíll be grateful,
Thanks
OfirLaor is offline   Reply With Quote
Old   January 11, 2012, 23:37
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
what is the extension of mesh file?
Far is offline   Reply With Quote
Old   January 12, 2012, 07:06
Ofir Laor
Well, Basicly I’m meshing in the Mesh software of ANSYS 13, and then open it with FLUENT directly from WorkBench.
However, I can export the MESH file as msh, meshdat and also poly,cgns,prj and tgf.
Old   January 12, 2012, 08:24
Far
Sijal
I assume your case is 2D, did you transform your mesh to x-y plane?
Old   January 12, 2012, 08:54
Ofir Laor
Yea, it is 2D on X-Y plane
Old   January 12, 2012, 08:58
Far
Sijal
could you explain your little bit more with snapshot of screen when you get the error. There may be many reasons !!!!
Old   January 12, 2012, 09:21
Default Relevant snapshots
Ofir Laor
OK, so here are two snapshots, which I hope can be relevant...
(Even though I couldn't find any useful information from this... )
The first is from WorkBench, and the second is from the mesh program of one of the attempts
Old   February 14, 2012, 10:07
N7student
Neraste is on a distinguished road
Hello OfirLaor and Far
I am sorry to hijack this topic, but I have exactly the same problem with ANSYS Workbench 13.0 and whatever the simplest geometry and mesh I try to make, I have the same error message : "The mesh file exporter failed during translation..."
Actually, I want to mesh a simple 2D square...
The difference with OfirLaor's case is that I cannot export my mesh in ASCII MSH file (I obtain the same error message); I can export in binary formats however.
Do you have any solution or advice for this problem? What is wrong with this?
Thank you a lot for your help
Neraste is offline   Reply With Quote
Old   February 14, 2012, 17:04
Ofir Laor
Hi Neraste,
Unfortunately I can't help... Never find any solution to my problem as well....
Good Luck
Old   February 14, 2012, 17:24
N7student
So, what did you do? Did you use another mesher software?
Old   February 14, 2012, 18:22
Ofir Laor
Well, this specific problem was the first out of 370 models I tested, in order to get some results, which I can analyse and compare between... So actualy, I didn't need a high resolution of accuracy. Therefore I solved the models with SolidWorks Flow simulation. However, if you're looking for a very accurate solution, I reccomend you to stay with Ansys... Please let me know if you find somthing... thanks
Old   February 15, 2012, 06:36
N7student
The fact is I build meshes with Workbench long ago (one year...). But now, I am completelly unable to create any new one, even the simpliest square. That is very confusing...
If I have any trick, I will tell you.
Old   February 17, 2012, 06:07
N7student
Well, I have some news for you OfirLaor !
According to my school IT supervisor, version 13.1p1 of WorkBench isn't supported by Ubuntu yet, but it is OK under RHE 5 or SLES 10. Since I am working under Ubuntu, this should be the reason of the error message.
Version 14 (and 13.0) should be (is) OK with Ubuntu. I will have a try with it as soon as my IT supervisor installs it.
Hope it helps.
Old   February 17, 2012, 07:52
jsm
JSM
jsm is on a distinguished road
For Fluent 2D analysis through workbench, we need to change the simulation type to "2D" before opening DM & Ansys mesher in workbench schematic. This will be available in properties panel. To get the properties, right click the fluent flow and select properties
Otherwise, Fluent will not accept the mesh. This might be the reason.
With regards,
JSM
jsm is offline   Reply With Quote
Old   February 17, 2012, 08:25
N7student
Well, jsm, actually I have already set this parameter on 2D.
I add I have tried a 3D cube and the result was exactly the same.
The OS incompatibility is reported on ANSYS' technical website (I don't have the source).
Old   February 17, 2012, 18:12
Post
  #16
John
villager is on a distinguished road
Hope it helps.
Yes, version 13.0 works quite good on Ubuntu Linux.
villager is offline   Reply With Quote
Old   February 20, 2012, 11:52
N7student
I have additionnaly some news for you! WorkBench on Linux needs a default Bash Shell (executables refers to /bin/bash). You have to set it up if your default shell is Sh or Tcsh (like in my school).
Old   February 20, 2012, 16:00
selcuk
sadir is on a distinguished road
this could be about cad file format. save as parasolid format may help you
sadir is offline   Reply With Quote
Old   April 9, 2012, 13:09
Ofir Laor
Hi Nerasta,
I got good news!
Apparently, my problem was easy… I used Workbench and there I had “Mesh” system (box) which I have created the geometry and mesh, and I linked the mesh to other “Fluent” system to the setup.
So that was somehow wrong to do… I did the same with one system of “FluidFlow (Fluent)”, and then I had no Error….
Hope this might help, Have a nice day!
Thread Tools
Trackbacks are On
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 40 January 20, 2016 01:08
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Native Meshers: snappyHexMesh and Others 2 March 27, 2011 21:11
Meshing aifoil in ICEM student123a ANSYS Meshing & Geometry 13 December 8, 2010 11:40
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 05:49
