January 15, 2012, 11:54 |
Wing Tip Cells Highly Skewed
Jimmy
I'm trying to create grids for Hoerner's Tip for a turbulent solver. I'm using a C-grid for the LE of the half wing. However, I'm getting very skewed cells at the wing tip and I suspect it's the reason for divergence when the mesh is used in Fluent.
Please take a look at the attached images. Any suggestion on how I can get rid of these skewed cells? |
January 15, 2012, 12:28 |
you need to make the better topology in the tip region. For reference download the mesh files of DLR-F6 test case from NASA web site (icem meshing with tin and blocking)
January 15, 2012, 12:31 |
Jimmy
What topology would you suggest?
January 15, 2012, 15:17 |
check topology in these files
ftp://cmb24.larc.nasa.gov/outgoing/D...em/wb/icemcfd/ Also check this ftp://cmb24.larc.nasa.gov/outgoing/D...lock_icem_cfd/ Last edited by Far; January 15, 2012 at 15:36. Reason: Images |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
Highly Skewed Cells | chrisoturner | FLUENT | 7 | July 22, 2010 06:43 |
Highly skewed and inverted volumes in wing mesh | makaero | FLUENT | 0 | December 8, 2009 19:32 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 00:32 |
