Partitioning
I'm new in using Ansys products. I have create the geometry with DM. The geometry is complicated so I have partitioned it. Now I have many different solids. Than I have meshed it with the Ansys mesher. At the interface between the solids the mesh is disconnected ?! When I import it for example in Fluent, I have many separate domains of fluid. How can I connect theme? Shoud I create some connections before? If yes, how? Thanks Franco |
multi body
Dear you can make multibody parts (1part, more bodies), just select all the parts, right click, and form new part in DM. Regards |
