[Sponsors] | |||||
Rep Power: 2 ![]() |
Dear all,
mesh check is failing on periodicity check. I get many errors of the type: "shell 268991 has node 98118 which has no twin" The translational periodicity in my model has been set-up correctly and all periodic vertices has been associated in the right way. Can somebody please tell me what else could the problem be? Thanks a lot Rob |
Simon Pereira
Rep Power: 24 ![]() |
Do they look periodic?
The periodic check gets pretty "technical" on you. It asks you what parts to check periodicity for and then reports exactly about those two parts. So if you have a curve on one side that happens to be in a different part (lets say it is in "CURVES" and you ask it for a periodicity check between PER1 and PER2, it might start to complain because technically it can't find a perfect match in PER1 for the line elements along the edge of PER2 because they are sitting over in CURVES which it didn't check... At least that usually turns out to be the problem for me. If you don't think that is the problem, you can use subsets to help you get more out of that message. It tells you a node number, so go into mesh subsets (its a branch of the tree) and create a new subset by node number... Add a few layers and then compare that with what you see on the other side. Do they look ok? Can you see an obvious difference?
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
Dear Simon,
thanks for the help. I had all the periodic surfaces on 2 parts: "periodic1" for one wall and "periodic2" for its correspondent. The curves are in the "geom" part, together with the points. Do you think this could be causing the problem? The mesh looks periodic. Also it has been obtained from a starting 2D mesh that has been extruded. The original 2D mesh is periodic and does not fail the check (and has been also successfully imported and analyzed in fluent). I tried to take a look at the nodes where it happens by creating subsets as you suggested but I didn't notice anything irregular to be fair. Rob |
Simon Pereira
Yea, the problem may be related to the curves being in the geom part... When you checked the nodes with the subset was it nodes along those curves?
I guess it doesn't hurt to put the curves in the per1 or per2 parts and try again... Or if you think everything looks good, you could just send to the solver see how that likes it.
Dear Simon,
sorry for the late reply but I could not work on the problem the last week. I tried to import the mesh in fluent but it crashes during import. Have you got any other suggestions? Rob |
Simon Pereira
No sorry, I would need more info to generate more suggestions...
Dear Simon,
I did a more deep investigation of what happens by creating subsets and I noticed that, apparently all the errors are coming from only two blocks (see the picture attached). What I don't understand is what's happening. The periodicity is assigned correctly to the vertices of the blocks and so it's the same for edges association. What can it be? Thanks again! Rob |
Ah, I forgot to tell that the subsets in the picture are not the only ones giving error but they came from a random sampling of all the nodes in the error list.
I think that all the nodes in the periodic surfaces of those two blocks are source of periodicity errors but they are the only ones in the mesh. Rob |
#9 |
Keeping investigating I noticed that (referring only to the two blocks giving periodicity problems):
1) all the elements on the periodic boundaries are interested by the error but not all the nodes on the periodic boundaries are 2) by decreasing the number of nodes on the periodic edges (I tried the value of 5 elements) the error disappears. Rob |
#10 |
I found a solution to the problem. I don't know what ICEM was doing but I guess that extruding the original mesh gave it some kind of problems of unknown nature.
I tried to delete one of the two blocks and then recreate it again, reassigning the periodicity to the edges and it worked. Hope this will help whoever will have the same problem in the future. Rob |
#11 |
Simon Pereira
So we never figured out what was actually wrong, but at least you learned how to use the subsets to locate the problem and then you were able to figure out a way around it... Good job.
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| 999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 | UDS_rambler | FLUENT | 2 | November 22, 2011 09:46 |
| IdeasUnvToFoam Bug amp Fix | benru | OpenFOAM Bugs | 42 | November 13, 2009 07:59 |
| shell conduction @ thin walls | Jiri Beran | FLUENT | 0 | May 18, 2008 14:08 |
| License server not visible from master node | Charles | FLUENT | 0 | October 30, 2007 18:48 |
| Please help cannot start lamboot | hsieh | OpenFOAM Installation | 8 | May 24, 2007 14:44 |
