[GAMBIT] how i can check my pump mesh
Like Tree1Likes
  • 1 Post By tareqkh
Old   January 29, 2012, 17:21
Default how i can check my pump mesh
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
I design my pump on gambit and i mesh it on the same program how i can test my meshing?????????????
behruz likes this.
tareqkh is offline   Reply With Quote
Old   January 30, 2012, 01:21
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
what do you mean with test?
In Gambit you can examine your mesh
http://my.fit.edu/itresources/manual....htm#gc_exmesh
Else you can load your mesh into fluent, and then do a check mesh
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
mesh check failed / degenerated contact points shohin FLUENT 16 April 11, 2014 22:32
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
