[ICEM] Problem with mesh importing in CFX
Old   February 15, 2012, 15:56
Default Problem with mesh importing in CFX
Frank Weise
FrankW is on a distinguished road
i've build up a blocked mesh. This is my first one. After that i've generated an unstructured mesh. And at the end i exported it as cfx5. If i open it in CFX 13, i get the following message:
I have no idea what caused the error. Any hints are welcome. Additionally i've attached geometrie and blocking file.
thanks for help!
with best regards
Frank
FrankW is offline   Reply With Quote
Old   February 16, 2012, 10:39
Rikio
rikio is on a distinguished road
Send a message via Skype™ to rikio
Refer to this thread, http://www.cfd-online.com/Forums/cfx...-mesh-cfx.html
There are weired blocks at the tip of the diamond like geometry, numbered 41 & 42 in the attached figure. Did you get this blk with the build-in tools?
rikio is offline   Reply With Quote
Old   February 16, 2012, 11:13
Frank Weise
..yes, all the blocks are created with build in methods. I've tested today a previous version of my mesh and it works. The blocks are shown in the attached picture. I make two operations after this version. I 've merged the vertices at the cone end. And i create a o-grid. I will test now witch operation is cause of that.
Old   February 18, 2012, 05:40
Frank Weise
Problem solved! The reason was the merging of the 2 vertices at the cone end.
Old   February 18, 2012, 08:42
Rikio
Thanks for let me know. So merging vertex should be used with care.
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
Problem in importing the Mesh fred Siemens 4 May 13, 2005 13:36
Problem importing ANSYS mesh, please help Ankan Kumar FLUENT 1 February 2, 2003 09:38
fluent mesh importing problem Phil FLUENT 0 February 19, 2002 04:44
