-   ANSYS Meshing & Geometry (
-   -   [GAMBIT] thick mesh at the end of the geometry (
Danath February 4, 2012 19:44
2 Attachment(s)
Hi i have designed arc 1
Now i want to make mesh more thick at the edges of the geometry arc 2
How can i do this?
Far February 5, 2012 10:24
What do you mean by thick mesh? As I am understanding you are talking about fine mesh!! increase the number of nodes there.
Where is arc 1 and arc 2?
Danath February 5, 2012 14:47
Arc 1 and arc 2 are the photos that i have post.
i want to condense my grid in the boundaries!
how can i do that?
-mAx- February 6, 2012 02:30
did you check the skewness of your cells? I am pretty sure you have skewed cells at arc's extremities.
Anyway you will have to fix it, and for that you need to avoid tangential split to arcs (you may move this split further away from arc)
Far February 6, 2012 02:40
then increase the no. of nodes on those boundaries. mAx is right about the skewness
