[GAMBIT] thick mesh at the end of the geometry
Old   February 4, 2012, 18:44
Default thick mesh at the end of the geometry
Evangelos
Danath is on a distinguished road
Hi i have designed arc 1
Now i want to make mesh more thick at the edges of the geometry arc 2
How can i do this?
Danath is offline   Reply With Quote
Old   February 5, 2012, 09:24
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
What do you mean by thick mesh? As I am understanding you are talking about fine mesh!! increase the number of nodes there.
Where is arc 1 and arc 2?
Far is offline   Reply With Quote
Old   February 5, 2012, 13:47
Evangelos
Arc 1 and arc 2 are the photos that i have post.
i want to condense my grid in the boundaries!
how can i do that?
Old   February 6, 2012, 01:30
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
did you check the skewness of your cells? I am pretty sure you have skewed cells at arc's extremities.
Anyway you will have to fix it, and for that you need to avoid tangential split to arcs (you may move this split further away from arc)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 6, 2012, 01:40
Far
Sijal
then increase the no. of nodes on those boundaries. mAx is right about the skewness
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
error using combination of step function xujjun CFX 1 January 15, 2008 16:46
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
