Home > Forums > ANSYS Meshing & Geometry
[GAMBIT] Volume meshing
Old   February 5, 2012, 23:00
Default Volume meshing
Ijaz
Ijaz is on a distinguished road
Could anyone help me with this problem of meshing. I need to observe the pressure and velocity distribution at the surface shown in the figure...
The part 1 is rotating as well as the outer cylinder is also rotating..how should I divide the part inorder to obtain the right answer..
Ijaz is offline   Reply With Quote
Old   February 6, 2012, 02:41
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Split cylindrical Tank with the other.
Then ask you, if you want to use MRF or Moving Mesh
http://my.fit.edu/itresources/manual...e365.htm#68192
If you are using interfaces, then you need to disconnect your volumes.
For that (once you did the split) you can copy the outer volume which rotates with 10rpm with a translation's vector, then delete the original volume (not the copy). Take the advantage of this view to apply interface BC to both volumes (one interface-BC for one volume >> meaning you need 2 interfaces because of 2 volumes).
Now move the copied volume with opposite translation's vector.
Both volumes should appear as earlier, but they are now disconnected (and you already defined interfaces)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 8, 2012, 05:22
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
Quality of mesh is not good enough. Put boundary layer on tool and other important surfaces. If possible make the hexahedral mesh.
-mAx- suggestions are valuable and accurate
PS Ijaz sent me files privately
Far is offline   Reply With Quote
Old   February 8, 2012, 22:56
Ijaz
Sir,
Yes, the problem is because of meshing...could you help with the boundry layer, on the algorithm and the edge/face I should select for the same..i am finding it tough to mesh the part..pls suggest step by step..i would be grateful to you..
I did as you said for the interfaces max ..but bec of quality of mesh the results are not coming...
Thread Tools
Trackbacks are On
'Tetrahedral meshing has failed for volume...' Murat FLUENT 5 February 19, 2011 05:22
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
Meshing volume F.A. FLUENT 3 December 12, 2005 02:31
volume meshing nikita FLUENT 1 July 3, 2003 01:25
Patran Volume Meshing Deb CFX 19 April 17, 2003 10:56
