[ANSYS Meshing] Extruding 2D mesh to 3D mesh in ANSYS meshing |
February 6, 2012, 09:01 |
Rachit Prasad
Hi everyone,
I have been working on a 2D flow over an airfoil in fluent. I had generated the mesh in ANSYS meshing tool. It was an unstructured quad dominant mesh. Now, I have been told to extend the problem in 3D by extruding the same surface mesh in the z direction to convert it into an volume mesh. How could this be accomplished? I know a surface mesh can be extruded in ICEM CFD, but I have been told to do it for the same mesh, so it has to be done in ANSYS meshing only. Thanks in advance! Regards, Rachit |
March 27, 2012, 02:40 |
Has anyone come up with a solution to this issue? I am having the exact same problem. I can figure out how to extrude a 2D mesh in ICEM to 3D quite well, but how can I do this in Ansys Meshing? Thanks!
March 30, 2012, 08:55 |
Matthias Voß
Rep Power: 20 |
i´ve managed to do so by creating a swept mesh,and set the source and target face manually. this means you have to redo ALL your meshing steps at the source face ... so maybe this isn´t what you were looking for.
neewbie |
March 30, 2012, 22:58 |
Sarang Dalne
I guess you have created a sheet/surface model for your analysis. When in the meshing application expand the geometry tree node.. go to the body of interest, now in the details view of that body there must be a field of thickness. give whatever you want. Thanks, Sarang |
July 31, 2012, 06:03 |
Jordi
Apparently, a surface can be meshed, a thickness specified and a 2D analysis performed. I'm only missing the possibilty of setting inflations...
July 31, 2012, 06:32 |
Jordi
But I found it's possible to right-click on the meshing method, the select 'inflate this method' to select edges.
February 14, 2024, 06:22 |
Rep Power: 7 |
can you please elaborate the steps?
February 14, 2024, 07:49 |
Gert-Jan
Rep Power: 27 |
Have you seen the dates?
February 14, 2024, 07:57 |
Rep Power: 7 |
February 14, 2024, 08:04 |
Gert-Jan
Rep Power: 27 |
It is a matter of managing expectations.
Better start a new query with a well written up-to-date question than to expect people are still there after 12 years. Also, the software has changed significantly since then, so possibly they have a solution that doesn't work for you. |
February 14, 2024, 08:19 |
#11 | |
Rep Power: 7 |
2d meshing in ansys meshing | syler3321 | ANSYS Meshing & Geometry | 10 | November 1, 2012 20:42 |
How To save a created mesh file in Ansys Meshing | ashtonJ | CFX | 4 | January 7, 2012 22:04 |
ANSYS meshing help | s.garg | ANSYS | 1 | November 12, 2010 04:11 |
[Other] Ansys meshing - periodic mesh for fluent | jsm | ANSYS Meshing & Geometry | 4 | September 24, 2010 14:25 |
Problem importing ANSYS mesh, please help | Ankan Kumar | FLUENT | 1 | February 2, 2003 08:38 |
