[DesignModeler] Is it possible to change the sketch plane in DM?
Old   July 11, 2012, 19:58
Default Is it possible to change the sketch plane in DM?
Riley Gorder
rgorder is on a distinguished road
I am new to DesignModeler and ANSYS Meshing and I have ran into the following problem. I created a 2D surface in DM to mesh and export to FLUENT...
My problem is I created the surface in the YZ-plane and apparently I cannot export my geometry in 2D unless I create it on the XY-plane. This was not the case in Gambit, which I am more familiar with... Is there a way to move a sketch to a different sketch plane?
Thanks for any suggestions
rgorder is offline   Reply With Quote
Old   July 11, 2012, 20:29
Default Figured it out!
Riley Gorder
I figured it out after beating my head against the wall long enough! Here is what I did...
Export a script detailing the desired sketch....
File > Write Script: Sketch(es) of Active Plane
Click on the sketch plane you want your sketch in (in my case the XY-plane) and run the script.
File > Run Script
Simple solution... just not an easy one to pin down if you are used to other programs such as SolidWorks and Gambit
Old   July 12, 2012, 02:39
Novosiberian is on a distinguished road
I have also read in DesignModeler instructions from ANSYS about the function called "Sketch Instance". May be it will help the others.
"Sketch instance allow you to place copies of existing sketches in other planes" (C)
Best regards,
Novosiberian
Novosiberian is offline   Reply With Quote
Old   July 12, 2012, 12:35
Default Comment about Sketch Instances
Riley Gorder
Novosiberian:
I had tried that but it did not work in my case as I wanted to move the sketch to the XY-Plane. Here is a snippet from the ANSYS manual explaining it in more detail.
Since a Sketch Instance must lie in a plane later in the tree than the base sketch (unless the base sketch is a plane boundary), the XYPlane does not have an option for creating a Sketch Instance.
Best,
Riley
design modeler, fluent, meshiing
Solid/liquid phase change fabian_roesler OpenFOAM 10 December 24, 2012 06:37
Change cell zone index/thread during simulation neilduffy1024 FLUENT 0 January 17, 2011 09:40
Meshing a Mixing Plane in ICEM Will Anderson ANSYS Meshing & Geometry 2 November 9, 2010 09:16
Requesting plane properties: DEFINE_DPM_OUTPUT Julian K. FLUENT 0 December 21, 2008 05:44
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 07:16
