February 14, 2012, 16:59 |
Question about Inputs
Brian Henry
Rep Power: 15 |
Hello, thanks for reading this. I have a bit of a interesting question I hoped you can help me with.
I'm working in constructing airway geometry, and I have a MATLAB code that constructs the first n generations of airway trees. However, something that I'm trying to do now is take that geometry and convert it into a mesh format. What I have now is similar to a old-style Fluent MSH format, where I have two main sections: point coordinates and face connections. So, my ascii MSH file for my face section consists of the Fluent MSH header, along with the connections (which are 2-point based lines instead of 3-point based surface triangles and 4-point based tetrahedrons). It looks like: (0 "Faces:") (13(0 1 1F 0)) (13(3 1 1F 3 0)( 2 1 2 0 0 2 2 3 0 0 2 2 4 0 0 with the point coordinate section pretty much identical. My question is: what would be the best way to take this into ICEM CFD? I tried manually inputting some of the points and manually constructing cylinders, but is there an easier way to bring this in? Once I bring this into ICEM CFD I can convert it to an IGES or STL, because what I ultimately want to do is merge this with STL's of the lungs and torso for COMSOL simulations. However, my initial problem of creating the geometry seems to confund me. I appreciate any advice you can give, and thanks in advance. |
internal field question - PitzDaily Case | atareen64 | OpenFOAM Running, Solving & CFD | 2 | January 26, 2011 15:26 |
question on bounday layer modeling | Wen Long | Main CFD Forum | 2 | November 12, 2005 17:29 |
Poisson Solver question | Suresh | Main CFD Forum | 3 | August 12, 2005 04:37 |
Philosophical CFD question | Richard Howe | Main CFD Forum | 14 | June 17, 2001 14:41 |
question about horizontal oscillation of naca0012 | Du | Main CFD Forum | 3 | May 10, 2001 07:39 |
