-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] Problem with mesh importing in CFX (http://www.cfd-online.com/Forums/ansys-meshing/97372-problem-mesh-importing-cfx.html)
FrankW February 15, 2012 15:56
2 Attachment(s)
i've build up a blocked mesh. This is my first one. After that i've generated an unstructured mesh. And at the end i exported it as cfx5. If i open it in CFX 13, i get the following message:
http://www.cfd-online.com/Forums/att...1&d=1329335184
I have no idea what caused the error. Any hints are welcome. Additionally i've attached geometrie and blocking file.
thanks for help!
with best regards
Frank
rikio February 16, 2012 10:39
1 Attachment(s)
Refer to this thread, http://www.cfd-online.com/Forums/cfx...-mesh-cfx.html
There are weired blocks at the tip of the diamond like geometry, numbered 41 & 42 in the attached figure. Did you get this blk with the build-in tools?
FrankW February 16, 2012 11:13
1 Attachment(s)
..yes, all the blocks are created with build in methods. I've tested today a previous version of my mesh and it works. The blocks are shown in the attached picture. I make two operations after this version. I 've merged the vertices at the cone end. And i create a o-grid. I will test now witch operation is cause of that.
FrankW February 18, 2012 05:40
Problem solved! The reason was the merging of the 2 vertices at the cone end.
rikio February 18, 2012 08:42
Thanks for let me know. So merging vertex should be used with care.
