[GAMBIT] Conformal Mesh
Like Tree1Likes
  • 1 Post By -mAx-
Old   February 17, 2012, 05:37
Default Conformal Mesh
felicemastronzo's Avatar
Felice
felicemastronzo is on a distinguished road
Hi all,
I have imported in Gambit a geometry made by many separate volumes. It is possible to connect the different volumes (not to unite them) in order to have a conformal mesh?
Regards
F
felicemastronzo is offline   Reply With Quote
Old   February 17, 2012, 06:27
Default What solver will be used?
m9819348's Avatar
Ries Bouwman
m9819348 is on a distinguished road
Send a message via Skype™ to m9819348
What solver will you use?
In FLUENT, you can combine non-conformal meshes and/or make them conformal. Other tools have similar options.
Regards,
Ries Bouwman
m9819348 is offline   Reply With Quote
Old   February 20, 2012, 10:07
Felice
I need a conformal swept mesh between 2 adjacent volumes in order to have a 2.5D dynamic re-meshing. So I need to create the conformal mesh in directly in Gambit. How can I do it if I have some adjacent but independent volumes? It is possible to "connect" them in Gambit in order to obtain a conformal sweep between the 2 volumes? If yes, how?
Regards
F
Old   February 21, 2012, 05:58
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
connect faces
http://my.fit.edu/itresources/manual...m_face_connect
Mojtaba.a likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 22, 2012, 14:11
m9819348's Avatar
Ries Bouwman
This is indeed the solution.
Felice, did this solve your question?
Dr. Ries Bouwman
Business Development
ESI Group
004369917171525
@riesbouwman
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
Conformal Mesh in Multi Phase Flows ziyasaydam STAR-CCM+ 2 March 16, 2010 15:29
conformal vs. non conformal mesh otho Main CFD Forum 2 May 30, 2008 11:11
