Boundary condition is lost when export to Fluent ( attached image )
Hi everyone ! As title
That is a part of small cylinder ( submerge in large cylinder ) . Can you show me the wrong spot ? http://ni2.upanh.com/b5.s25.d1/8918f...8772.block.pnghttp://ni4.upanh.com/b3.s13.d3/3bf1d...74.cutplan.pnghttp://ni6.upanh.com/b4.s15.d1/6e735...rttofluent.png Here , i have ICEM files http://www.box.com/s/pelth7k8704vlxbdy7j3 Thanks for reading :D |
modified files (cyli_mod) http://www.4shared.com/rar/pSIUuhhK/Smallcylinder.html
Just changed name of solid to fluid (should not make any difference) and deleted few internal surfaces (thin wall, not needed in this case) and every thing is fine now. Also divided wall into wall1, wall2 and wall3 depending on curvature change. selected pics: http://img72.imageshack.us/img72/9987/cylinder1.png http://img192.imageshack.us/img192/5254/cylinder2.png http://img195.imageshack.us/img195/295/cylinder3.png Together we can learn better |
First ! I appreciate your help :D next...the problem still hasn't solved . It will be easier when you watch the flash file below ( can open by browser ...IE, Chrome ... :D ) compare on ICEM & Ansys Meshing . Code:
http://www.box.com/s/nne68io62ajx7ciyqll0 |
if you are talking about interior then interior name is changed by icem and you get the different name . For example it is int_fluid instead of just fluid, just change the name in boundary condition panel
http://img27.imageshack.us/img27/953/cylinder4.png http://img836.imageshack.us/img836/2418/cylinder5.png |
The problem has solved . I just create thin wall block :D and other way ? thank again ! |
tin and blk http://www.4shared.com/rar/-DHDr2qt/Smallcylinder2.html http://img850.imageshack.us/img850/1283/cylinder6.png http://img94.imageshack.us/img94/3550/cylinder7.png |
Yes , it is shared wall :D but why I can't creat wall4 like you ! , "Volume part" in "associate face to surface" must be a part of blocks :confused: http://ni7.upanh.com/b1.s25.d1/04858...7487.khkjh.png |
For specifying the inner wall, the correct procedure is here...
http://www.cfd-online.com/Forums/ans...nner-wall.html |
