Home > Forums > ANSYS Meshing & Geometry
[ANSYS Meshing] Help needed in meshing multi-stage turbine using Workbench
Old   March 1, 2012, 12:49
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
I am going to use Ansys Workbench for meshing, so whether i can directly export the geometry to the workbench or extract the fluid volume and then export only the fluid volume for meshing. Which is the best strategy?
This all can be done in Workbench Design modeler. You can put the enclosure (fluid volume) in DM.
I can send ANSYS meshing 14 tutorials if needed.
as i mentioned earlier there is a tip clearance between rotor blade and casing, also between stator blade and casing.
I want to the study the effect of tip clearance, So could you please explain how to mesh.
Just mesh the complete volume from hub to casing, no need to segregate the tip clearance volume from main fluid.
Far is offline   Reply With Quote
Old   March 2, 2012, 00:39
KGN
mecbe2002 is on a distinguished road
Could you please send me the Ansys tutorial
Thanks
Regards
mecbe2002 is offline   Reply With Quote
Old   March 3, 2012, 06:22
Far
Sijal
Sent. check PM
Old   March 3, 2012, 08:46
KGN
Originally Posted by Far View Post
Sent. check PM
Thank you very much
Regards
KGN
Thread Tools
Trackbacks are On
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 42 July 18, 2011 22:11
Meshing Volume in Gambit for a water turbine Zaqie FLUENT 1 July 24, 2009 01:25
Marine current turbine (meshing and stimulation help needed!!) coolyihao FLOW-3D 0 March 16, 2009 12:48
Q: how to do a good meshing in turbine usin gambit oscar FLOW-3D 1 March 15, 2009 00:15
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 06:01
